Bilgepump9
- Aug 22, 2015
- 2
I purchased this Boat & Motor just a year ago. I have about 35 hours on it since I purchased it. Last May it stalled due to lack of fuel. (When I pump the squeeze bulb it would fire back up) I replaced the bulb and the boat ran fine for about 1 hr, than it did the same thing. It seemed to get progressively worse, I took in in for the 500 hr service and described my symptoms. Dealership completed the work and said I had a clogged secondary fuel filter on the engine. Once again, after about 1 hour of use, the same symptoms began. When I pump the bulb , the engine starts right up, I may need to complete this cycle once or twice and than it will run fine, until the next time I shut it down. One other note, when the engine is not running the bulb does not get hard, but with engine running it does get hard. When I do squeeze the bulb, it sounds like it is sucking air somewhere, but I have no unusual fuel smells and fuel leakage evidence. Thanks in advance for your help
