My 1988, DT140 seems to be overcharging. The voltage gauge is running around 15V at any mid range rpm. Then it blows the 25A fuse (one of 2) that is in the CDI enclosure area, next to the CDI unit. When this same fuse blows, all the gauges stop working. The engine will continue to run, but if you cut it off it will not restart. If you replace the fuse it will start up and then blow the fuse again a few minutes later. Any ideas??? Thanks Jon.
