Im working on a 98 Suzuki 25hp 3 cylinder. First off the motor is hard to crank. Once it fires up its good and it idles good. Put it in gear and go but it doesn't feel like it has the power that it should. The carbs have a milky liquid in the throats. And condensation build up on the out side of the carbs. I've rebuild the carbs, cleaned them twice and drain the gas out of the tank and lines. Also I just drained the oil resivor to see if water was in the oil but it looks clean. Any ideas what might be causing this ?
