riverboy460
- Mar 26, 2007
- 30
Can anyone point me in the direction. I need to go. I tried removing my outdrive today but it's frozen on there. Can't get it to budge. I replaced my engine and put both brand new water pumps on. I can o ly get rhe raw water one to pump water if I remove the inlet from the front of the cooler on back of engine and use a garden hose in the line.
If I can figure this out all I have to do is fix a few small other issues. Like tach doesn't work and trim gauge is stuck at up even when. Down all the way
I tried backing it into the launch ramp today with no luck there either. It flowed for a little bit but I think that was just spitting out the rest of the water that was in it fro. The hose test yeaterday.
