capnmatt
- Jul 18, 2015
- 15
I purchased a project boat that i am working on. It is a Wellcraft 250 Coastal with 2 Volvo Penta AQ145A engines. One engine is missing from the boat (I have collected almost an entirely new motor in my garage that i am just starting to build. The other motor is in the boat but i had to rebuild the top end. Sometime in the past someone added an electronic ignition module to it - so the condenser and points are gone.
So here are my main set of questions. The coil is not getting any power. It looks like the main power source that powers the coil is direct from the alternator (or is it possibly a voltage regulator mounted on the alternator??) it puts out 0.9 volts. I see an in-line resistor. The electronic ignition is connected to the coil as well along with a while wire that looks like it is for the tach. this white wire is connected on the negative side.
i disconnected the wire leading to the alternator and connected a 12v line direct to the battery. When i do this the engine will run, sputter, and die. i am not able to give it any gas or it will die.
i installed new plugs. the carbs are getting fuel. when the engine is running the timing is to manufacturer specs.
i do not know how the coil is supposed to be wired. I am wondering if i am overloading the coil? (It gets VERY hot) from what i can tell it is a Bosch coil with a 3 ohm internal resistor. (If i did the resistance test correctly)
PLUS - i don't understand how there isn't a + wire attached to the coil fed from the ignition switch?? Is this somehow supposed to be controlled from the wire leading from the alternator to the coil?
I'm also wondering if i have issues with the carbs / fuel / adequate fuel pressure. when i open the carbs the front solex carb's accelerator pump squirts gas but the back carb does not. otherwise both carb fuel chambers are filling with gas.
so for starters - Does anyone know how this coil set up is SUPPOSED to be wired?
thanks
matt
thanks
matt
