Hey everyone I have a 1984 Larson Delta conic with the Volvo Penta AQ 125 motor my problem is I can fill the coolant for the motor and as long as I do not reopen the coolant side the level will stay fine but if I open it when warm I sometimes find the coolant level drops and it pours out the exhaust not sure what's going on here. it may even be dumping into the raw water side too. Not sure what's up motor does not run hot actually runs great any help would be appreciated thank you
