I have a Four WInns with a 2003 VP 5.7Gi-C duoprop
I have traced an intermittent fuel pressure issue to the connector on the low pressure pump.
Sometimes I get the required 50 PSI but other times I only get 10-20 PSI.
The connector on the fuel pump side is not replacable, and the male pins on that side seem OK, so I need to get one that fits that same style.
When I look in the Volvo Penta parts catalog it is part of a complete wiring harness,
Does anyone know what style of connector the TWO PIN FEMALE connector is on a Volvo Penta Fuel Pump.
This is one with the wire bar that holds the connector in place.
If necessary I will go back and take a picture, but that will have to be in a few days.
thanks,
Dale
thanks,
Dale
