I have a 1998 Regal 2100 LSR with a 5.0LPBYC Volvo Penta engine in it. Since i bought the boat the engine will stall out on the first start attempt but after that it would run fine for hours. Finally, the last time i tried to take it out it did its usual and stalled but this time it won't start back up. It ttys to turn over but won't. It will turn over if i spray some fluid in the carb but will quit when that dry's up. I checked the fuel filter and it looks fine and has some fuel in it. The fuel injected fuse looks fine and has 12volts. I hear no humming coming from the fuel pump. I checked the plug going to the pump too and no voltage. So is it a Fuel Pump issue or electrical. Any help would be appreciated.
