Just bought the boat and changed the gear oil. It was full of non-metalic shavings. I pulled the outdrive and then the top cap that houses the dip stick. The boss on the underside of the cap shows a lot of wear from the shaft nut rubbing on it. When I spin the prop the shaft raises up about an 1/8" and obviously rubs on the underside of the cover. What is the cause? Do I need an upper gear assembly???
Thanks!
Thanks!
