I have a 2003 stingray with the 3.0 in it. To start off the head gasket blew a few weeks ago so I had pulled it off and checked and reinstalled. It cranks up and runs good on the hose but when put in the water and under this load of the weight it runs not so good. It will idle good and you can get up to about 1500 rpm no problem. When you start to throttle up I would estimate about 25% to 75% or so of throttle the engine does not want to take off. The best description I can give it is basically just runs real rough and will not build up power to drive the boat. Now if from idle The throttle is put all the way to 100% the boat jumps up and runs just like intended and gets up to 4500 rpm running 45 or so no problem. After running this speed for a minute it tries to die down to 3k rpm. ITs odd because about 25% to 75% of throttle it runs like crap and doesn't want to accelerate. I felt as though this is a fuel issue but hoping someone has had similar issue and can lead me in right direction. Also could something stemming from the head gasket replacement cause this like valve being out of adjustment. I followed the service manual correctly setting the valves and this is not the first motor I have rebuilt so I am confident in my mechanical abilities. Any help would be greatly appreciated. Thanks
