dick-shotgun
- May 26, 2015
- 2
Hello, my name is **** and I was just recently gifted an old 1979 bayliner with the aq120b Volvo penta 270. It wasn't running when I got it. Would turn over but not start. So I pulled the carb gave it a good cleaning and checked the timing. Turns out the timing was off so I adjusted it and it fired right up first try. Unfortunately it won't idle unless I feather the throttle or put it above 1/2 throttle. If I try to bring it down to idle it chugs, spits some crap out of the carb AMD then dies out. Any suggestions?
