Boaterguy05
- Jul 1, 2014
- 19
I am changing the gear oil in my out drive today. Previously, I had burned up a clutch from over filling the drive. This time I followed the proceedure exactly. I removed the drain plug, dip stick on top and the air bleed screw. I pumped in the oil from the bottom until it started to flow out of the air bleed. My manual says 2.2 quarts, but this took more like 2.5 quarts. The manual also states that the oil level should come to the top of the flat portion of the dip stick. My question is this. With the drive unit level, oil flowed out of the air bleed, but it is only showing half way up on the flat part of the dip stick. Should I add a little more or call it good? From what I was reading, once it flows out of the air bleed it is high enough. This is a 2005 Chaparral with the 5.0 GXI-E and the SX-M 1.60 drive. Any thoughts are greatly appreciated.
