jrgcbg40
- Apr 29, 2007
- 35
Hi, I just took my boat out of winter storage. It started up quickly and I ran it about 1500 rpm for a few mins. When brought back to idle position it was really rough and died.
These are the specs on my engine. 1997 4.3 GS PLKD 4 barrel holly carb. This will be my 3rd year with the boat. I winterized it by opening the block drains and all hoses from waterpump and took out the thermostat. I then filled the hose to the waterpump with antifreeze 50/50 green car stuff. (the year before the pink stuff looked like a slushie in my rv toilet so thats why I opted for the green.) I then re-installed the hoses and therm housing. Put the muffs on and had my son start pouring in the antifreeze through a section of garden hose and funnel. I started the engine and he poured 4.5 gallons of the green in. I then fogged it and let it stall. I always keep fuel stabilizer in the gas. I tested the antifreeze in the catch bucket and all the ball floated so I figured it was good. I didn't re-drain the block this time as I thought it would be better for corrosion purposes to leave the anti freeze in. I also changed the oil and fuel filter. My fear is something went wrong and maybe I cracked the block or heads?
So for testing I replaced the spark plugs, drained and refilled the gas tank and re-installed the thermostat. Did a re-start and it started right up again but still had the rough running at rpms below 1000 and died when put in neutral. I sprayed carb cleaner in while it was at 1500 rpm. Let it run to operating temp (about 15 mins) then tried to bring it to neutral and it stalled.
My next step was going to replace the distributer cap and rotor as I don't know if or when they were changed. But after looking at my photo's I saw one plug that was cleaner than the rest. Making me think it maybe a head gasket or riser problem?
I did a compression test with a cold engine and throttle full open. Results #1 190 psi,#3 190psi, #5 190 psi. #2 180 psi #4 180psi # 6 170 psi. I did # 6 twice just to make sure I turned the tester in tight enough and it tested at 170psi again. So its an 11% variation from the 190 to 170?? Is this bad enough to cause my symptoms? The carb was also rebuilt twice by the boat dealer because they said there was junk in the tank. last year I added a stiffer spring to the secondary because I had a bog on accel and that fixed it. Boat ran fine before putting away?? Which direction should I go now? Thanks in advance for your help.
