Travmad804
- May 5, 2015
- 3
http://forums.iboats.com/forum/engine-repair-and-maintenance/volvo-penta-i-o-inboard-
Im having the same issues with my 85 Bayliner Capri Cuddi Cabin 2.1 Volvo Penta. Im new to the page, also new to boating in general. Im more of a car guy and do my own repairs but Im leery jumping into a lower unit. When I hook the hose up with the muffs Im not getting any water coming back out of the exhaust. What exactly is the pump on the motor (with the two copper lines) for? Is that for coolant like a car with a radiator? I thought the impeller would suck water up into the engine and pump it back out through the exhaust to keep the engine temp cool. Do you have any instructions or links that would help in replacing the impeller in the lower unit, and where to find a replacement part? Im having a hard time finding a replacement impeller or any instructions like a manual or someone that has done it with pics to help so I can do it myself. Any advice or anything anyone would like to share is much appreciated!
Re: 1985 bayliner 2.1 volvo penta I/O overheats
Hey, I have the same boat. If yours is a trophy? Any way ,the water will come out the exhaust. Which is the kinda triangular opening above the prop. There are two pumps,one for engine block. One is a raw water pump. The maual warns against running with out the thermostat? We do it with cars all the time? But do be careful if you do that. There are lots of places where you can have a small air leak in the raw water system. Even a small air leak can cause the pump to not work well. The fitting the other guy mentioned is often the problem. It can clog or even break. I have already replaced mine. The impeller is often the problem too. It is easy to replace,not too pricey. I have had some leak issues with the lines on this pump. Last time I took them off ,I used some gasket maker to help seal them. No problems since.
I have a twenty two foot trophy boat. She is slow,but steady. And a pleasure to fish from.
If I can help in any way just let me know. I am pretty good with this boat,as I have redone most of mine.
Hope it works out for you.
Eddie
