two bad
- May 4, 2015
- 7
Got a 1990 volvo penta 570A with a possible ignition issue. Every time i try to throttle up and get into secondaries it wants to backfire through carb and bog out. I believe my distributor advance is not coming in incorrectly thats were the problem begins they do not make replacement springs for prestolite distributor any more or so i cant find them. p.s. i tried the spring kits from parts store not strong enough spring. so i was going to replace the whole system with a electronic thunder bolt system anyone done it what problems occurred any other suggestions thinking thunder bolt because there much less costly the mallory or msd.
