Volvo SX-M Upper Unit Strainer
AMMO DAWG
I am putting a Volvo SX-M outdrive back together after painting and as I was ordering O-rings and going through the manual I came across something that I need some advice on. The parts breakdown on the "Volvopentastore" site for the upper unit shows a strainer, PN 3854021, but says the part is obsolete. When I search for the part online almost no one carries it anymore. I notice my upper unit ( I purchased it used) does not have any type of strainer installed. I assume its to filter the gear oil. So my question is has something changed and it is no longer recommended for use or is it just hard to find the part. Appreciate any insight you can provide.
AD
AMMO DAWG
No Title
Any body have any info or a good lead on a Volvo Outdrive expert? Part number 9 in the picture is what I am questioning, thanks
Fun Times
The original part number that this is no longer available was 0986814 (SCREEN Oil sump) then 3854021 and as you know is obsolete too.:(
Using the two numbers you're going to have call around and see if you get lucky. Also search online marine salvage yards. Here's one to try as a starting point. http://www.mmmarinesalvage.com/engines.htm
Hope you find something, good luck.:)
AMMO DAWG
Thanks FT, I'll try and hunt one down. Makes me wonder what its purpose is since it's so hard to find one. Better to be safe and get one installed, thanks again
AD
jerryjerry05
I was told.It's supposed to keep the nasty's out of the upper drive if the lower goes bad.
Sent U a PM
