I'm swapping my 3.0's fuel pump from the mechanical to electrical and need a bit of guidance on the wiring. I just want to make sure i get it right before I mess something up. I'm going from the stock one plug oil pressure switch, which if I remember correctly goes to the alarm, and the larger switch is for the gauge. My question is when I install the new setup with the 3 prong switch, which of the 3 prongs do I hook the old single prong alarm wire up to? or does if have to have its own switch?
Secondly is their anywhere in the back of the boat i can safely hook up the ignition wire, or should it be run directly to the ignition?
I attached a photo of the old and new setup side by side
Thanks in advanced for any and all responses
