Hey Guys
New here so here's my question
I am replacing the engine in my boat and can't find a timing shunt to set the base timing.
The engine is a 5.7Lt/350cid engine with throttle body injection. NON Vortec its the older 1st design systems from 1991.
I have the 4 pin shunt with the 2 wires looped and the aligator clip to B+ that is used in the distributor for newer model engines but this engine which is throttle body injected uses a 10 pin style connector near the front of the engine.
If anyone can give me a part number to purchase a shunt or instructions on which pins to connect to set the base timing or build my own for later use I will be eternally grateful.
My local Volvo dealer is really no help and will not sell me the shunt for the older model injection/timing system.
Thanks for any and all help with this
Dave
Dave
