Steve Oest
- Feb 2, 2015
- 4
I have a 2007 Regal 3060 with twin 5.0 OSI engines. Bought it last year. The boat had XPD plastic drives which were coming apart and needed replacement. The trim gauges worked as designed and were accurate (note the trim gauges are Faria). This fall a local volvo dealer replaced the complete drives with new DPS A drives and transom plates the trim senders are new as well. While reviewing their work I tested the trim gauges.With keys on and the drives down the gauges read half up. I tried to adjust the senders and they are adjusted all the way down. I pulled one off and moved the pin and i cant get the gauge to show any lower than half down. While raising the drives the gauge begins to work when the drives are physically 1/3 up and then begin to work to show all the way up the rest of the cycle. both drives and gauges have the same fault I spoke to the dealer and they suggested I replace the gauges. I tried three types of gauges and all do the same thing ( wont read below half down). I tried in line resistors, didnt work, Faria stated I need the resistance measurement form the senders but the senders are three wire and I cant find any wiring diagrams to show what wires to use or what wires to measure from. Has anyone ran into this before? I am at a loss.
