smassey22180
- Apr 15, 2013
- 210
I made a mistake installing my new intake manifold and I got water in my oil. Can I use a GM oil pump priming tool to flush most of it out? I plan to do an oil and filter change, run the priming tool for a while and then repeat until it looks clean. I still have the intake off so I get a good view. Normally I would just run the engine on muffs however this is frowned upon in our community. It would take 15+ minutes to get heat to the oil and the neighbors would not like the noise. I plan to use a heat gun on the pan overnight to heat the oil. This worked well to get the bad oil mix to syphon out.
Auto zone has the tool as part of their loner program. http://www.autozone.com/loan-a-tools/oil-pump-primer/oem-gm-v6-v8-oil-pump-primer/534529_0_0/
thanks
thanks
