1994almeida
- Mar 29, 2006
- 140
I removed the stern drive unit SX-M, in order to lubricate the U-joint and inspect Bellows.
Now, during the installation, I have to tighten the 6 elastic mounting bolts nuts to 50 ft lbs, that securing the upper unit to the transom bracket.
I have one torque wrench ? in drive cliper type, but is too large to tighten the 6 elastic bolts.
On my local area I can?t find one 3/8 wrench small enough to tighten this bolts.
Could you please inform one wrench brand that should be small enough to tighten this bolts, which I could by at e bay.
Thanks
Thanks
