Redeye1620
- Jul 11, 2013
- 39
I purchased a 1985 Nordic Viking with a cracked block. I did rebuild the engine using a 1996 Vortec block & heads. The engine sits on an engine stand in my garage. Before installing it I want to go thru the out drive. My plan is to remove a 290 upper gear box to check and replace the u-joints & PDS seals & bearings. I have purchased the u-joint bellows. Are there any other gaskets or o-rings needed to complete the job? Also, are the u-joint, seals & bearings still available for this older outdrive? Thanks in advance for your expertese....-Rich
