First, and even if I get no response, thanks for the best boating forum on the Internet.
I own a meticulously maintained Volvo 5.0GL engine installed on a Wellcraft 200SS I/O, driven by an SX outdrive. My kit has less than 500 hours of operation. The kit runs well, with good power and no impairments whatsoever except that on first startup after overnight storage, it requires a pump of the throttle and a few seconds of cranking to pull fuel to start. Once started, the motor pops right off.
Timing is good, valve adjustment and compression good (~170 in each cylinder), normal temperature, no vacuum leaks, spotlessly clean and well maintained -- all is well.
At the end of the season, after a day of pulling skiers and cruising, the motor lost power during a 2900 RPM cruise to the launch. It gradually spooled down. Upon immediate restart it fired up. After a few minutes of cruise, it did it again. With a boat full of worried people, I drove back just off idle. It did not stall at low RPM.
The boat is in my driveway and about to be winterized. Winterized AFTER I diagnose and fix this problem!
THE KNEEJERK DIAGNOSIS: I think it is my fuel cap. I have a Perko cap and a while back the gasket failed. I replaced it with an O-ring. It seals really well. I can recall that if I run the tank down, when I unscrew the cap to fuel up, there is a loud sucking sound. sssssssssssssszzzzzzzzzzzzzzzzzzzzz! I believe the tank is not venting. I believe that I ran the motor so long that day, I pulled vacuum to the point where the fuel pump could not feed the motor. That also correlates to the motor firing after restart (pressure recovers), and that it ran at low RPM without stalling.
Here’s the thing: That can not be verified in my driveway. I can run the motor with the cap off, but unless I’m pulling load and developing vacuum in the tank, the failure mode can not be replicated.
It could be the fuel pump, FP relay, or wiring also. So: here is my plan:
- Test at the fuel pump relay. Engine on, verify power from alternator to relay. Verify no interruptions. Verify good quality ground.
- Replace fuel cap/filler assembly (the Perko design appears to be inferior anyway and replacement gaskets are not available)
- Assuming fuel pump, relay or wiring correction are not indicated (above), run motor 5 minutes in driveway.
- Figure out a way to connect a fuel pressure gauge – ideally as a permanent engine health monitoring feature.
- Buy a fuel pump and relay (keep as a spare), failure to do so will guarantee a ruined boating weekend with a campsite full of adults and children – This is the promulgation of Murphy’s Law.
