Hi Guys
Am at my wits end and hope someone can point me in the right direction. I have a Volvo Penta 200d with a 280 sterndrive.
Problem is that when the engine gets up to temperature (142 degrees) and I put it into idle, usually sits about 800-900 revs, the water stops pumping out of the sterndrive. As soon as I put the revs up a bit, about 1000, then the water starts to come out of the sterndrive.
I have replaced the impeller, even thought the old one is only 1 year old. Taken the engine pump off and it looks fine, no broken fins. Replaced the drive belt, taken off the exhaust manifolds and risers and given them a clean out (they were pretty clean anyway), replaced the thermostat and checked all the hoses.
Totally stumped as to what to do next, any help would be very welcome.
