smassey22180
- Apr 15, 2013
- 210
What is the proper Volvo procedure for adjusting the idle mixture on a 2 barrel Holley on a 4.3? I can't seem to find it in the factory service manual PDF I have. I assume it is set idle speed to 650 running in forward gear and then adjust the idle mixture to get the fastest RPM. My main confusion is there are 2 mixture adjustments. One on each side of the carb.
My boat is running great but occasionally stalls when I put it into gear after a warm start. I took it apart today to clean and rebuild and it looks new inside. Also, we probably will take the boat to lake Tahoe next spring and it most likely will need adjustment due to altitude.
thanks
thanks
