wellcraftexcelcrap
- Dec 6, 2011
- 13
Ok, I have a gm 350 crate engine with vovlvo sp drive in a 93' wellcraft excell 23se raw water cooled All of the sudden the temp gauge started reading apx160-170 should be at 142 or at least that is where my thermostats is set to open. When I feel the engine one bank is way hotter than the other. Left side is hot looking aft. Also it looks like I have a sheen of gas or maybe oil in my exhaust. I also had a guy tell me I was running rich on one side after he changed out my spark plugs. I seem to be getting really good flow out of both sides of exhaust and recently changed out my manifolds and risers. Also impeller was recently changed. My game plan is to first change/inspect oil for water. Next do a compression test. I also want to take my carburetor off and have evaluated as it looks like prior owner fed with it and put it back on with gasket stealer. Any other recommendations on where to start would be helpful.
