MHave
- Sep 22, 2014
- 1
Recently my starboard fuel pump quit working due to loss of power to the unit. Upon investigation I found 2 things wrong...1) the wiring from the harness to the fuel pump was burned near the quick connector; 2) the fuse for the fuel pump was blown. After replacing the fuse and rewiring the unit, the boat started up immediately and a successful sea trial was done. Upon returning to the dock and shutting down the engines to let them cool prior to flushing, the engine would not re-fire. Any ideas as to the cause of this wire/fuse problem and what the fix is?
