Volvo Penta Hydraulic Oil
gapple12
Is there a particular hydraulic oil I need to use in my boat for my Volvo SX out drive ? Its looking a little low so I figured I would top it off.
skydiveD30571
Volvo recommends Volvo Trim/Power Steering Fluid. I just used PS fluid from the local auto parts store.
gapple12
Looking at the reservoir, it looks a little below half. Now, since I bought the boat I haven't seen it move. I figured i would just top it off.
gapple12
Which reservoir are we talking about here?
Facing my engine compartment, there is a reservoir off to the side with the hydraulic lines going to the outdrive. Not my power steering pump. I didnt know you could use power steering fluid as hydrolic fluid, can you ?
HalfFish5087
Whats the model no of your outdrive? However, I understand that Volvo recommends Volvo trim/steering fluid or Dexron ATF.
skydiveD30571
They are one in the same. Which is why Volvo markets theirs as trim/steering fluid. It is used in both the power steering pump and trim pump.
muc
Make sure your drive is all the way down when you check/adjust oil level.
