OK, I checked the wiring and it is definitely a bad sender. I have a DPSM outdrive, 2 wire sender.
Anyone have experience changing these out? How difficult is it to get to the little plug that fits into the transom shield, remove the clip, re-insert, etc.
it doesn't look easy to get at from the outside, or from the back side (behind the engine, very tight).
Or do I just clip the wires, solder and heat shrink like I used to when my merc senders went bad?
