Browndog801
- Jun 5, 2013
- 12
:blue:
I noticed last year my gamble bearing had water in it and I replaced it and put on a new bellow. Towards the end of the year I noticed I was still getting water inside the boat. I pulled the outdrive did not see water in the gamble bearing. I think it's in the transom seal. I grabbed the transom and lifted and no movement from the seal but when in the water and backing it up, water is seeping in the bottom of the transom. I got a mirror and a flashlight and at the bottom of the transom it does seem to have a small gap in the boat, the transom feels strong but it must be week somewhere making the seal fell. I have two options one is to go ahead and pull the motor and transom and fix it right. The other is to caulk around the outside with 3M 5200 and see if it will last this summer. Money is a little tight right now after TAX'S. I'm sure if I pull this off I will probably have to buy a few extra parts and special tools. The seal must be gone and don't know if anyone's tried sealing around the exterior for a temporary fix and how long it could last. What special tools will I need and parts should I replace?
