barnstormerj
- Jun 13, 2011
- 33
I have rebuilt my 1991 4.3l engine, it has been line bored, balanced, new crank, rods, bearings, oil pump ect. Ran it last summer , break in, was not to concerned, it seemed to show about 35lbs oil pressure , cruising at about 3-4000 rpm, ,I am a certified auto mechanic, most times 20 lbs is sufficient with a gm engine, idle oil pressure in a car engine can run at 5-10 lbs with no problems,. My boat runs bout 15 lbs o.p. idle 170 degrees f. What do boat mechanics usually agree on with oil pressure ranges? thought about a new sending unit, but do not think there is much need for concern, engine runs fine.
Also, what horsepower would this engine make ( ruffly) it started I believe at 175, as a two barrel carb, it now has the cam and holley 4 bbl off of a 225 hp engine?
