I rebuilt the Solex PA 44 on my Aq131a using Mikes Carbs video and parts.
No matter what I do to adjust the fuel mix and idle it just wont idle correctly. It seems to be fine but when I rev it up and then throttle down it takes forever to respond and idle down. Then it idles fine for a short time and then kinda roller coasters RPM until it starts coughing and missing and dies.
It will idle well at RPM that is above an idle it should be shifted at... cant seem to get it to idle at a low enough rpm to comfortably shift.
I recently replaced the fuel pump.
I tried running the engine using fresh gas by placing the fuel line in a new can of gas. No luck.
Any one know of a similar problem with a solution?
Thanks for reading...
Ed
Nothin works on an old boat except the owner.
Ed
