mrclean667
- Nov 12, 2012
- 6
Have a 1999 Glastron with 5.7 GSI. when you turn the key nothing happens. Plenty of juice in the batteries, you can hear something kick on when you turn the ignition to the on position, but when you goto start it nothing.
Figured it might be solenoid, but replaced it and still same issue. However, when we wired the solenoid (mercruiser solenoid, was told it was the same as OMC by dealer) and the yellow w/red stripe wire was on one of the smaller posts, and we turned the battery swith on, it would engage the started with out using the key. It was wired the same as previous solenoid. Just for fun I made sure and switch the wires and nothing.
So solenoid works, but getting the solenoid to work sounds like the issue.
what else could it be. it was doing this intermittely last year and started again this weekend. Ending with not being able to turn over the motor at all. Things to look at, go over??
Thanks guys!!
J
Thanks guys!!
J
