yes took prop off looked in where shaft is and it is full of oil can't really see where it is coming from might be more then i can fix myself but oil is a green color don't know if its gear oil or power trim fluid ?green oil leaking from behind my prop dont know way ?
Power trim is usually red.
There shouldn't be anyway the T/T fluid can get to the prop area.
The green oil is probably gear oil.
You need to drain and pressure test the lower.
Profile?Location? U might be close to someone who can help???
yes i will take it to my guy and will post what was wrong and what was fix thanks
