Re: dp-s stainless forward prop frozen on shaft cannot drain oil from drive?
dp-s drive stainless forward prop frozen on shaft cannot drain oil?
Ayuh,.... Welcome Aboard,... That's because the props haven't been pulled, 'n the shafts greased, annually,...
At this point, try penetratin' oil, a dead-blow hammer, or a puller to get it off,...
Dependin' on how bad it's stuck, the decision whether to beat it off, or Cut it off will come soon enough,...
