oregonrafter
- Aug 22, 2011
- 27
I'm replacing my Volvo 305 with a rebuilt chevy 350, and I want to use a full cooling system (engine coolant circulates through engine and manifolds). As far as I know, there is no Volvo riser and manifold combination that will work for this configuration. The mechanics I have talked-to, say that Volvo does not make a full closed cooling system, and that I will probably have to convert to Mercruiser components if I want to do this. My question is, have any of you done this? If so, what is required for the conversion? I'm concerned about the connection from a Mercruiser riser to a Volvo Y pipe. My concerns are as follows:
1) Is the Mercruiser manifold and riser a similar height to the Volvo manifold and riser? If not, how big of a spacer do you need between the manifold & riser?
2) I understand that the Volvo riser diameter (output end) is approximately 3 3/4" and the Mercruiser is 4". How do you deal with the change in diameter?
3) is the Volvo riser output angle similar to the Mercruiser riser angle? If not, how do you deal with this?
Thanks for your help! -Mike
