Re: Water fuel separating kit (moeller)
Thanks but no there just like an oil steel my concern is the top of housing is in printed outboard use only
Whats the bottom of the filter look like. I'll bet it's got a clear/plastic on the bottom so you can see the fuel/water. The inboard or i/o doesn't have this. Coast guard Regs is you can't have clear plastic bowls below the floor.
Standard Clear Site Water Separating System (033314-10, 033328-10, 033341-10 Out board
Superflo Clear Site Water Separating System (033347-10, 033348-10, 033349-10) "
Clear Site Water Separating System for Inboard Engines (033339-10) inboard engines
•Aluminum bowl meets industry fire test requirements.
Is this what it looks like.
