rickyregal
- Jan 23, 2014
- 3
Installed a new Volvo penta shifter with trim and noticed that when you move the shifter forward its smooth but the more you move it forward the stiffer it starts getting. It does the same thing in reverse. Not sure if its a cable issue or do I need to adjust throttle friction screw? How can I troubleshoot to see which one it is. If its the screw how do I actually do it. I know where the screw is, but is there a process like can I do it in neutral or do I need to put the shifter in throttle mode and then turn the screw counter clockwise?
