7.4GL PHUS S/N4110126342
It has been about 8 months since this boat was started, but last time it ran fine. Went out this week to get it running as lake here in Texas has finally come back up where I can get it out of the boathouse. Starter motor would not run, so have found that problem and replaced the relay that sends 12V to the solenoid. Now with a new battery it cranks over very good, but still would not start. Here are the things I have done so far, but need help. Have read most of the posts I can find about starting problems and now I need help.
1) Replaced battery with brand new cranking battery.
2) Replaced relay that controls the 12V to the starter solenoid. Now cranks over good.
3) Made sure kill switch is in place.
4) Checked spark from coil and it is good (spark jumps from 1/2 inch away to ground)
5) Checked spark from spark plug. only pulled one plug, but got good spark. Plug was not wet and was not burned and still had proper gap (.035)
6) Checked coil resistance (did not remove coil wires) but primary had <25 ohms and secondary had >11,000 ohms, so think this is good. I don't have a coil tester and not sure my battery in the DVM was good enough to get real low reading. Have heard about weak coils, but don't know how to determine.
7) Checked fuel pump and disconnected fuel line from carb and when key set to crank got a good stream of fuel pumped out. Screen inline was also clean. Don't have a pressure gauge.
8) Looking down carb and moving throttle have fuel squirting into carb, so it is getting fuel.
9) Removed fuel filter/water separator and poured gas that was in filter into glass bowl, no water in fuel and looked clean. I had put stabil in the fuel, always do.
So, now I am a loss of what to do next and would appreciate any suggestions. I may be slow to respond as boat is 60 miles away at lakehouse.
