111torrance111
- Jan 8, 2006
- 273
I (Friend) have a 2008 Reinell with a 305 HP Volvo Penta, while out fishing this last week end I heard the buzzer which I assusme was low oil and then the engine shut down within a few seconds.
Looked in the bilge and it was full of oil, tried adding oil and it too just empty into the bilge.
Prior to this everything seemed fine as this boat gets used almost every weekend, it has just over 1100 hours and is used in salt water. The bilge is typicall dry & clean so I don't suspect a rusting oil pan.
I can't get down in the engine area enough to see anything, any thoughts on what to look for short of pulling the engine? I assume this motor must have an oil plug (Bolt) thet coulod have came loose. I haven't drained the builge yet to see if I find the bolt, but was thinking to run a maganet down there to see if the bolt was down in the oil.
Any advice/help would be appricated.
Jerry
Jerry
