74bayliner
- Aug 23, 2011
- 607
If you have the 270/280 outdrive with the Mechanical Lift/tilt device. Can you please tell me how it operates?
I have an old one that i am trying to rebuild, because it did not run. I got it running and it works but i want to be sure that before i go ahead and close up the relay box (ive opened and closed it 10 times already without checking my work... stupid me! but i was so sure i had it
So when you turn on your ignition your engine is locked in the up position when you get into the water, since it is in the up position the Warning indicator light is lit, correct?
Than you essentially press Down(lower) switch and the 12v motor winds away until it hits the limiter switch (fully down position) and the motor stops. Correct? That way you cannot damage the motor by making it work when it has no more place to go...
Than when you are done, fishing boating or what have you, you come back to shore and you press the Up (Raise) switch, which in turn Raises the outdrive, ... my question is. The up (raise) button does it have a way to know when you have gone to far? (such as the limiter switch for the Down(lower) switch) or do you raise it only to a certain point, to be able to lock it, than lower it.
If someone could make a video of the Lift/Tilt operation and post a link i would greatly appreciate.
For those of you who would like to know how to rebuild one of these, I am putting together some videos which i will show you how i rebuilt mine and all of the costs etc. that way you can see if its cost effective to do it yourself.
Any help is appreciate thank you!
