Re: Volvo 430b sp-c help
I do not have step by step, but only the upper unit needs to be removed. A good search here should turn up something, I will try to find some details later if I can.
I also remember some postings where the bearing was replaced from the outside when no bearing race issues were found. Sometimes the actual PDS housing can be damaged if the bearing/race was run for a long time with issues. The success stories were for single bearing units, some configurations have 2 bearings. I will look for details on that as well if I can. Work is getting in the way of my recreational stuff, sigh.
