I have a 2003 Volvo 5.0 GXI with a DP-SM out drive, I need to remove the steering arm off the gimbal ring. Lower pivot has been removed, All four nuts and washers removed, center bolt removed. The service manual states, use puller 3854361 to remove arm, it seems these pullers are hard to come by, I've searched online, talked to our marina mechanic, no luck finding one. I have read some post that say just make one, which I'm fine with, but I don't get what I'm pressing on, the bolt in the middle, the four studs and the two dowel pins are all attached to the gimbal ring so what does this tool press against? Of course the swim platform is right above it so hard to see down in there, any advise greatly appreciated.
