Re: Saltwater in lower unit fluid Flushing Question
Last time I got water in mine the oil got very thick and sticky.
I flushed it a couple times with straight diesel, then went to hydraulic oil , a couple flushes with that then
engine oil, 15-40 or something then let that drain overnight and then used Volvo synthetic gear oil.
If it is just a little water in the oil and it drains quickly like straight oil would, then I just let it drain for as long as possible, overnight is good, then put in new gear oil, no flushing. I put at least 500 hours a season on my outdrives,,,,water in the oil is not uncommon , I always pressure test before I repair anything , to make sure I am replacing the correct parts, it's usually the shaft seals and once in a while the u joint drive shaft bellows. Once it was actually a cracked top cover.
