Ontherox27
- Oct 29, 2013
- 12
How does the impeller in a 290 DP get replaced? I've looked through my manual and it never mentions anything about the implore on lower unit only the water pump?
No impeller in the drive on Volvo units.
You have to plug the hole under the drive on front of the bullet case, then hook up the muffs. The impeller is mounted on the crankshaft and it's probably fried now from being run with little or no water because some dude didnt plug up that hole.
