Re: Tilt/Trim Problem on Volvo Penta 3.0 GXi with SX/A Drive
hello I have the same trim pump as elf62. but mine is leaking fluid from behind the cover plate. the pump is still working but its gushing out fluid. so basically I cannot raise or lower my trim without topping off the reservoir. and of course leaking fluid all over in the water. does anyone have a fix for this that doesn't require replacing the pump?
