gapple12
- Sep 15, 2013
- 174
During my first winterizing of my boat this past weekend, I changed the oil, oil filter, fuel filter, gear oil, and then proceeded to drain the block. I pulled the manifold plugs, no problem, but when I laid down to pull the block drains, there are hoses attached to them on both sides feeding into a hose attachment capped off. So, I pulled the cap and let it all drain. Is this OK or should I pull the hoses off and drain from the block ? The hose was full to the top with water so I'm guessing the drains cant be clogged or needing to be reamed out ?
