Re: AQ130 brass cooling tube sealer?
I agree that, with perfect alignment, there should be no problem with the cooling pipes being held in place at the mounting points provided. Some of us aren't professional mechanics, and make some pretty dumb mistakes, or start with some pretty bashed up equipment. I was providing a fix that I've used. I've also spend hours in frustration, trying to tweek the pipes this way or that to get the factory fit. If you can get the correct fit, by all means go for it. If you've struggled with those, as some of us do, then you'll be willing to settle for a less than perfect fit that still does the job, and doesn't look too amateurish.
