This came from a friend on another site.
Very good Volvo guy.
Read this thread. Some of these guys don't have a clue.
http://forums.iboats.com/volvo-pent...es/volvo-260a-280upper-290-dp-leg-629812.html
The reason for engine oil in the s/p drives, is due to the gear/bearing design, and mainly due to the slinger pump. These slinger pump impellers are made from die cast aluminum. If heavy gear oil is used in a s/p drive, there is a risk that the slinger impeller drive pins may become sheared off.
With the Duo Prop addition, this oil must be GL-5 gear lube.
There is NO slinger pump in the DP lower unit.... instead, the driven gears pump the gear lube up to the transmission.
There is NO risk to this type of oil pumping with heavy gear lube.
Plus, the DP requires this additional GL-5 lubrication that engine oil cannot provide.
This is NOT an option!
Now.... the one issue that some may run into, it the cone clutch affair.
Some sliding sleeves (that have spent years in engine oil) will not lock up with the heavier GL-5 gear oil.
There's simply too much friction reduction.... and some degree of friction is needed for the eventual lock-up.
The remedy is simple.
The transmission is taken apart, and the sliding sleeve is gently lapped into each corresponding gear cups.
This is not a big deal.
If the transmission is in need of re-sealing, and/or bearing cross replacement, you get to kill several birds with one stone.
