after having a ujoint seal replaced and new bellows, did a test run on the boat, now a loud whining , high pitch squell, coming out of outdrive when i put it in gear, the noise goes away in neutral, all so ihad the gimbal bearing and u joint assembly replaced, now the new u joints are knocking bad when i turn the boat, knocking noise wasnt as bad with old u joint's in it, should i be able to hear knocking or chatter noise from the o joint's when running it on the trailer? i can hear the noise when on the trailer, witch get's worse when the boat is under a load in the water, any idea's? mechanic said noise is normal, sounds like the u joints are coming apart, engine alinment has been checked twice, the whine was not there until the outdrive was removed and the u joint seal was replaced, havent been able to use my boat since may, scared of doing futher damage to the out drive, any idea's where to go from here?
